View productMiniature shoulder milling cutter with incomparable stability
Square shoulder milling endmills with small diameter with exceptional stability and productivity
Features:
– Exceptional stability
Unique shape of the Insert and its positioning on the cutterbody provides larger support below the insert.
V shaped insert bottom avoids inserts movement during machining.
Obtuse angled flank face of insert strengthens cutting edge and avoids chipping.
Wider insert cross-section improves insert strength and allows larger screw size.
Larger screw size of M2 compared to M1.8 reduces screw neck shears under high cutting forces.
– Precise machining
Sharp cutting edge with large rake angle ensures smooth cutting.
Periphery ground insert provides highly accurate machined wall and surface finish.
– Inserts
2 types of insert geometries cover wide variety of material machining from steel, stainless, cast iron, aluminum to heat resistant superalloys.
Applications:
– Shoulder milling
– Slotting
– Ramping
– Plunging and traversing
– Helical interpolation
– Hole enlarging
ISO Application Range:
