Highly productive roughing cutter with serrated edges
Long-edge rough milling with small chips effectively prevents chatter
Features:
– Anti Chatter Design
Wavy cutting edge shape creates smaller chips reducing chatter.
– Intelligent and User friendly design
Each flute (adjacent pockets in radial direction) in the cutter body is offsetted in Z direction. This positioning ensures that the insert in the adjacent flute removes the crest left by the previous insert. Thus, the surface of machined wall is close to be flat.
No specific insert positioning required as positioning is done on the cutter.
All cutting edges of the Inserts are identical.
Insert corner is strengthened to resist corner chip off for the bottom most insert.(the bottom most insert is a single effective corner and withstands the feed equal to feed/rev)
– Insert Varieties
2 types of insert fit on the same cutter body providing option for roughing as well as finishing.
Applications:
– Shoulder milling
ISO Application Range:
