DoForce-Tri is a new series of tools with double-sided triangular insert performing general milling applications with superior advantages.
High-precision shoulder milling cutter with economical double-sided triangular inserts
Insert features: – 6-cornered design for economic advantage – Fully effective cutting edge length in square shoulder milling – Low cutting force even in large depth of cut – Concave cutting edge & optimized rake angle form barrel-shaped chips, delivering smooth chip evacuation
