Cogsdill help with the production of Ventilators
Cogsdill are receiving several enquiries for 9mm internal roller burnishing tools, and 1mm diameter micro burraway…
View productWe’re talking Heads!
The ZX Facing & Contouring heads offer the greatest versatility of all from the Cogsdill ZX Tooling range. These heads have a single tool slide onto which top tooling is mounted into qualified locating holes. This provides for repeatable set-ups.
With appropriate top tooling, these heads can perform boring, facing, O.D. turning, grooving, taper boring, radius forming, chamfering, recessing, and threading. Large parts can be machined without having to remove the work piece.
Internal through coolant is standard across the range.
Product features:
Perform Lathe-type operations on boring mills
Maximum application flexibility – machine I.D.s, O.D.s, faces, tapers, radii, and contours.
Large Diameter Range (from 0mm to 1700mm on ZX900)
Accepts industry-standard top tooling components and inserts (Modular tooling packages also available)
Qualified tool location points in tool slide for accurate and repeatable set-ups
Extremely rigid and durable design
High material removal rates
Backlash-free operation
Operating principles
ZX Facing & Contouring heads offer the greatest diameter range of movement (up to 254mm / 10.0 inches) in one set-up. Six standard head sizes are available with actuation ratios of 2:1 and 1:1, depending on the model selected. Special modifications are available on request to accommodate unique part requirements. See comparison table for further information.
Modular tool slide adapters are available to meet the machining requirements of most components. These adapters are also offered in a range of commercially available tooling systems such as Capto®, ABS®, KM® and others.
We hold ZX200, ZX300 and ZX420 heads in stock.
Available for immediate shipping!
Multiple Functions. Maximum Flexibility.
The most versatile solution to increase the productivity of your HBM.
ZX 200
ZX200-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 200mm
Maximum Stroke 38mm
Maximum Boring Diameter 500mm
Maximum Speed 800RPM
Compare the heads
ZX 300
ZX300-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 300mm
Maximum Stroke 75mm
Maximum Boring Diameter 800mm
Maximum Speed 500RPM
Compare the heads
ZX 420
ZX420-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 420mm
Maximum Stroke 102mm
Maximum Boring Diameter 980mm
Maximum Speed 350RPM
Compare the heads
ZX 500
Z500-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 500mm
Maximum Boring Diameter 1060mm
Maximum Speed 300RPM
Compare the heads »
ZX 700
ZX700-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 700mm
Maximum Stroke 127mm
Maximum Boring Diameter 1330mm
Maximum Speed 250RPM
Compare the heads
ZX 900
ZX900-TC Facing and Contouring Head
SPECIFICATIONS
Slide Length 900mm
Maximum Boring Diameter 1700mm
Maximum Speed 150RPM
Compare the heads
