Radius cutter with serrated cutting edge for anti-chatter
Serrated cutting edge on insert provides low cutting force and reduces chatter for long overhang applications
Metric PDF , Inch PDF
Features:
– Available in serrated insert and round insert
Serration type: 4 indexes per insert
– Smooth chip evacuation due to small-chip formation
– Low cutting force
– Reduced chatter in applications with long overhang
Regular round type: 8 indexes per insert
– A single cutter body for both types of inserts
Tight fit and rigid clamping due to unique insert boss
ISO Application Range:
Product Line-up:
E-catalog(Metric) , E-catalog(Inch)
