Radius cutter for profile milling of complex parts
Innovative and safe anti-rotation system, featuring FIX insert location provides highly rigid clamping.
Features:
– Anti-rotation system with rigid clamping
Secure insert seating on protrusion of cutter body
Cutting force pushing insert towards pocket, resulting in rigid clamping
– Round insert with 6 indexes
No need to take off screw to change cutting-edges
– High-cutting speed Vc up to 300 m/min (984 sfm)
ISO Application range:
Product Line-up:
E-catalog(Metric) , E-catalog(Inch)
