Economical face milling cutter with high productivity for all materials
Highly rigid cutter with double-sided, tough insert with 10 cutting-edge provides remarkable efficiency at high feed.
Metric PDF , Inch PDF
Features:
– Economical, double-sided insert with 10 cutting-edge
Positive rake angle and inclination on cutting edge for low cutting force
Neutral M-class insert applicable for both right- and left-hand machining
AH3135 grade with high chipping resistance and ability to workpiece materials on steel and stainless steel
Cermet grade providing excellent surface finish for soft steel
– Cutter body:
Available in coarse, close, and extra close-pitch cutters for a wide range of machining requirements
ISO Application Range:
Product Line-up:
E-catalog(Metric) , E-catalog(Inch)
