High spec Kafo Vertical Machining Centre with Direct Drive Spindle and Fanuc data server
Visit us at www.tdt-machinetools.co.uk for more information on specification, brochure, price and availability Or call us on 01788…
View productAvailable now to ship from Feeler works (Subject to prior sale)
SHB-13030RM Horizontal Boring and Milling Machine
Axis Stroke: X 3000mm
Y 1800mm (2500mm option included in stock machine)
Z 1500mm (1700mm optional included in stock machine)
W 700mm (900mm optional)
Distance from table centre to spindle nose 585-2085mm (585-2285mm optional included in stock machine)
Axis max Rapid/feed rates: X 10m/min – 5m/min
Y 12m/min – 5m/min
Z 12m/min – 5m/min
W 5m/min – 5m/min
Table Dimensions: 1800mm x 2000mm
Max Table Load: 15,000kg (20,000kg optional)
B Axis Minimum increment 0.001° accuracy ±5”
Spindle Drive 2 Speed ZF Gearbox
Spindle diameter 130mm
Spindle Taper BT50
Max Spindle RPM 2,700RPM (Without W axis – 6,000RPM)
Max spindle motor power (30min) 26KW (37KW optional)
Max Spindle Torque 1716Nm at 145RRPM
Automatic Tool Change
Number of pockets 40 (60 Optional)
Max Tool Dia (adjacent pocket empty) 245mm
Max Tool Dia (adjacent pocket in use) 125mm
Max Tool Length 400mm
Max Tool weight 35kg
Tool type (BT/CAT/ANSI or DIN) BT50
Pulls stud specification P50T-1
Machine Dimensions
W 6,682 (6,882 optional)
D 7,490mm
Max Height H 4,238mm (4,538mm 4,838mm 5,038mm Optional)
Machine Weight 42,000kg
Machine power 70KVA
Air Supply Mpa 0.6 ; l/min 500
Coolant tank capacity 500 litres
