RUR High Definition Plasma Cutting Machine (NEW)
*** Available for an August/September 2019 delivery and installation ! *** KERF RUR2500p Lincoln Electric Spirit II…
View productKerf high definition plasma cutting machine – advertised on behalf of a customer.
The machine is an RUR2000p fitted with Burny controller, Lincoln Electric Spirit 275 amp plasma, INOVA electronic torch height control with pneumatic safety breakaway, 6000mm long fume extraction cutting tables that are 1500mm wide. The machine could be supplied with a 3m cut length if that was preferable although the longer cut lengths means that you could pendulum load with two plates and cut longer parts in one piece such as staircase stringers.
The Lincoln Electric Plasma unit is capable of UltraSharp cut quality. It will pierce and cut material from 1mm through to 32mm thick mild steel. Supplied by Kerf in August 2015 the machine is in excellent condition and would make an excellent addition to any fabrication workshop.
The owner of the machine is selling his workshop and moving to much smaller premises without the space for the machine.
We are anticipating that it will be available for a September 2019 installation.
