SMEC NS2100 turning centre for sale
CNC lathe from SMEC with Fanuc 0iTF Plus control, sub spindle and Y axis options, 820mm…
View productDugard 1000 XP VMC for sale from stock. check out the spec below
X axis traverse
1050mm
Y axis traverse
540mm
Z axis traverse
560mm
Spindle nose to table
75~635mm
Spindle centre to column
550mm
Table size
1200 x 480mm
T slot
18 x 80 x 5 slots
Table load
980kg
Spindle taper
BT40/CAT40
Spindle speed
20~12,000rpm
Max motor power output
20kW Fanuc
Rapid feed X/Y/Z
44/44/25 m/min
