Correa FOX Bridge Type milling machine
The FOX combines traditional roughing capacity with the speed and precision of high performance machining controlling…
Honor VL-200CM Heavy Duty Vertical Lathe, new to DTS in the UK. Heavy duty vertical lathes now available in varying sizes, this particular model is spec’d as below
Max Swing: 2500mm
Max Turning Dia: 2500mm
Max Turning Height: 1600mm
Table dia: 2000mm
Spondle speed: 3-200rpm
ATC: 16 positions
Live Tool Spindle
